Dear readers,
I'am currently working on a tile witch contains air and water and needs to absorb and conduct heat.
I had made a lid in the box to divide the water and air from each other, but flowsimulation sees the lid as a barrier between them.
There is no heatconduction between them!
How can i properly setup the model so it does ?
Thanks in advance
Greetings
Koen
The Netherlands
That sounds strange! Since one of the most common application of defining fluid subdomains is for heat exchanger, which I assume that's your case. Did you turn on the heat conduction in solids option once your were setting up the problem?
