Ok I was using a linked dimension for awhile, but now have unlinked everywhere it is used and I don't want it to show up in the pull down menu anymore? Is there a way to delete or clean these out of the part/assembly? I know you could in previous versions, but I can't find out how to do so on SW 2016.
Note: I now want to use the same value as a global property equations. I can't re-use the value name while it is still there as a linked dimension.
That will do, or you can right click on Equations and then click on manage equations, select the raw and delete it.
