Is there a way to rotate a part around an axis to produce an outline of the part? I can figure it out manually but i was wondering if solidworks has the ability to take this part and spinning it creating an outline of part so i can use that outline as a drawing to turn on my machine (lathe).
Not sure if I understand your question correctly
There is an option to change the angle of rotation of you model in options which you can use the alt + arrow (left or right) to rotate your model
