design library tab has no icons.....completely blank. Help!
Thank you Deepak. I have done that. We have uninstalled and re installed SW2014. This has not helped. I only have icons along the top of the design library for Add to library, Add File location and refresh. I have tried the add file location button to point SW to the design library location with no success. I have also checked around our office with other SW users to make sure I had the right path to the design library. I have been trying to solve this for a couple of days now and the frustration level is increasing. Any suggestions would be appreciated at this point.
Luanne,
I know this is not correct, because it adds a new part that must be removed, but this is what works for me.
1. I do have the system mapped to the correct location.
2. However there are no icons to choose from so I open a part and select the option to add a new part.
3. Now I select a location to save the part. (this part will later need to be deleted)
4. and the icons magically appear. As I said probably not the right way to do it but at least I can find the icons. Unfortunately I need to do this again after every time I close SWx.
Hi Rahul. Thank you so much. This did work! Look up idiot in the dictionary and you will find my name! LOL!!!
Check and make sure that path for design library is set properly under Tools > Options > File Locations
