I'm trying to link a revision symbol to a dimension so that when the drawing changes, the revision symbol moves with the dimension.
I've already attached the revision symbol to the drawing view, and I tried grouping the symbol and dimension. This works when I'm moving the dimensions by hand.
However, when I change the part configuration, while the grouping of the symbol and dimension is maintained, the dimension shifts with the part while the symbol does not. In this case, when I change the part to a shorter configuration, the dimension shifts down with the part while the revision stays in the original position, which is now above the view. I can then move the two in unison, as they're still grouped, but there is now a large gap separating them.
Is there any way to group the two so that the revision symbol stays with the dimension during the configuration change?
Add it right at the dimension dialog box
