Hi there,
I'm trying to create a pattern like the one found in the image, but on a cylinder. Basically a hexagonal grid where each hexagon has a soft "scoop" taken out of it. Does anyone have any insight on how to do this?
Hi there,
Hi Jason,
I didn't match your scoop very well but you can generate the pattern you are looking for using Variable Pattern. I made the attached model in 2016 but the screenshots should help you if you have 2015 (the first year Variable Pattern was out).
Hope this helps get you going.
Jody
Couldn't resist having a go ,, that's a nice little problem
I didn't actually put any 'dimple' in it, its just a filled surface from a hexagon drawn on a cylindrical surface
The first thing I realised was that the hexagon size had to fill a cylinder perfectly so it's based on an angular dimension.
Its parametric up to the combine. If I was going to do it again I'd probably look at making a pattern of cuts instead of building up solids, but I was just learning
I did my example in under 15 min. - first few minutes was just confirming my guess that the flat pattern was pattern of shallow spherical cuts. then I tried a couple variations on making the pattern of cuts on a cylinder. them played with the parameters a little to try to approach the "hexagons" on the cylinder.
..agree,.. here is what I came up with..
