Use vba in Excel to print Solidworks drawing using Edrawings?
Question asked by Jamey Evans on Oct 20, 2016
I have a spreadsheet that is used to make job packets.  I have written the code listed below to print the drawing that corresponds to the part listed on the work order.  This is running from Excel and works great in Solidworks but our operations group is using Edrawings.  Can anyone help me with the syntax to make it work with Edrawings api?  I haven't been having much luck on my own and am relatively new to VBA.
Dim swModelDocExt As SldWorks.ModelDocExtension
Dim swPageSetup As SldWorks.PageSetup
Dim printSpec As SldWorks.PrintSpecification
Dim drawing As String
Dim errors As Long
Dim warnings As Long
Dim footerTextNumber As String
Dim footerTextCount As String
Dim footerText As String
Option Explicit
Sub printsldworks()
    swApp.Visible = False
    Call FindFilePath 'Sub takes part number from production sheet and finds filepath for drawing "tgtDir"
    If Len(tgtDir) > 0 Then 'If drawing exists then print
        drawing = tgtDir
        Set swModel = swApp.OpenDoc6(drawing, swDocDRAWING, swOpenDocOptions_Silent, "", errors, warnings)
        'Set up page's footer text
        Set swModelDocExt = swModel.Extension
        swModelDocExt.UsePageSetup = swPageSetupInUse_e.swPageSetupInUse_Document
            Set swPageSetup = swModel.PageSetup
            footerTextNumber = swPageSetup.GetHeaderFooterString(swStandardHeaderFooterPageSetupTexts_e.swHeaderFooterText_PageNumber)
            footerTextCount = swPageSetup.GetHeaderFooterString(swStandardHeaderFooterPageSetupTexts_e.swHeaderFooterText_PageCount)
            footerText = (footerTextNumber & " of " & footerTextCount)
            swPageSetup.CenterFooter = footerText
        'Create a print specification
        Set printSpec = swModelDocExt.GetPrintSpecification
        printSpec.ConvertToHighQuality = True
        printSpec.AddPrintRange 1, 1
        printSpec.FromScale = 1.5
        printSpec.ToScale = 0.5
        printSpec.ScaleMethod = swPrintSelection
        printSpec.PrinterQueue = ""
        printSpec.PrintToFile = False
        Debug.Print "Printing specifications:"
        Debug.Print "  Collate: " & printSpec.Collate
        Debug.Print "  Convert to high quality: " & printSpec.ConvertToHighQuality
        Debug.Print "  Current sheet: " & printSpec.CurrentSheet
        Debug.Print "  From scale: " & printSpec.FromScale
        Debug.Print "  To scale: " & printSpec.ToScale
        Debug.Print "  Number of copies: " & printSpec.NumberOfCopies
        Debug.Print "  Print background: " & printSpec.PrintBackground
        Debug.Print "  Print cross hatch on out-of-date views: " & printSpec.PrintCrossHatchOnOutOfDateViews
        Debug.Print "  Printer queue: " & printSpec.PrinterQueue
        Debug.Print "    File: " & printSpec.PrintFile
        Debug.Print "  Print white items black: " & printSpec.PrintWhiteItemsBlack
        Debug.Print "  Selection as defined in swPrintSelectionScaleFactor_e: " & printSpec.ScaleMethod
        Debug.Print "  Total sheet count: " & printSpec.SheetCount
        Debug.Print "  X origin: " & printSpec.XOrigin
        Debug.Print "  Y origin: " & printSpec.YOrigin
        ' Print the drawing to your default printer
        swModelDocExt.PrintOut4 "", "", printSpec
        printSpec.RestoreDefaults
        printSpec.ResetPrintRange
        swApp.QuitDoc swModel.GetTitle
    Else
        MsgBox ("Print Not Found for " & tgtFile)
Jamey
