WMWill Moody20/10/2016
Hi
I currently use a macro to save my drawings as dxf's and pdf's, this has caused issues if I forgot to update the dxf's and pdf's after updating my drawing (slddrw).
What would be really useful is a macro that replaced the Save button which saves as slddrw, dxf or dwg and pdf.
I have looked at my macro but cannot figure out how to change it to include a save as slddrw.
This is the macro code
    Set swModel = swApp.ActiveDoc
    ' Strip off SolidWorks drawing file extension (.slddrw)
    ' and add DXF file extension (.dxf)
    sPathName = swModel.GetPathName
    sPathName = Left(sPathName, Len(sPathName) - 6)
    sPathName = sPathName + "dxf"
    ' Show current settings
    ' Turn off showing of map
    bShowMap = swApp.GetUserPreferenceToggle(swDXFDontShowMap)
    Set swModelDocExt = swModel.Extension
    Set swExportData = swApp.GetExportFileData(swExportPDFData)
    filename = swModel.GetPathName
    filename = Strings.Left(filename, Len(filename) - 6) & "PDF"
    boolstatus = swExportData.SetSheets(swExportData_ExportAllSheets, 1)
    boolstatus = swModelDocExt.SaveAs(filename, 0, 0, swExportData, lErrors, lWarnings)
    If boolstatus Then
        MsgBox "Saved as PDF DXF successfully" & vbNewLine & filename
    Else
        MsgBox "Save as PDF failed you did somthing wrong dumb ass, Error code:" & lErrors '
    swApp.SetUserPreferenceToggle swDXFDontShowMap, False
    bRet = swModel.SaveAs4(sPathName, swSaveAsCurrentVersion, swSaveAsOptions_Silent, nErrors, nWarnings)
    If bRet = False Then
        nRetval = swApp.SendMsgToUser2("Problems saving file.", swMbWarning, swMbOk)
    ' Restore old setting
    swApp.SetUserPreferenceToggle swDXFDontShowMap, bShowMap
Many Thanks
Will
