PDM checkin error (24)
Question asked by Wesley Prins on Oct 19, 2016
Latest reply on Dec 9, 2016 by Andrew Johnson
Hello everybody,
I'm trying to create a new program for a automatic vault check in.
How ever i get the same error everytime and i don't know how to solve it.
Please find below my code, i will add the error and the action i already taken below the code
Dim swApp As SldWorks
        swApp = GetObject(, "sldworks.application")
        Dim swModel As ModelDoc2
        Dim swDraw As DrawingDoc
        Dim project As String = ""
        Dim Number As String = ""
        Dim Description As String = ""
        Dim note As String = ""
        Dim i_revOption As PDMWRevisionOptionType = 0
        Dim Revision As String = "A"
        Dim lifecycle As String = ""
        Dim RetainOwnership As Boolean = True
        Dim References As Object = Nothing
        Dim value As PDMWDocument
        swModel = swApp.ActiveDoc
        Dim filename As String = swModel.GetPathName
        project = SW_get_custom_properties("project")
        Number = SW_get_custom_properties("Number")
        Description = SW_get_custom_properties("Description")
        note = SW_get_custom_properties("note")
        Revision = SW_get_custom_properties("Revision")
        If string_is_nothing(Revision) = True Then
            Revision = "A"
        lifecycle = SW_get_custom_properties("lifecycle")
        Dim instance As IPDMWConnection
        instance = CreateObject("PDMWorks.PDMWConnection")
        instance.Login(mylogin,mypass, myserver")
        instance.Refresh()
        swApp.CloseDoc(filename)
        value = instance.CheckIn(filename, project, Number, Description, note, 1, Revision, lifecycle, RetainOwnership, References)
As error i get the text below:
There is no valid client license on this machine. (24)
i can checkin any file with solidworks manually without a problem
tried some solution on the net like
adding
C:\Program Files\Common Files\SolidWorks Shared;
to windows environnement variable
checked the vault licences
i have a solidworks professional licence.
Can anyone help me on a solution if there is one?
Thank you for your help
