Is there a way to quickly and easily replace downloaded (imported) part models from vendors without breaking the mates?
For example: I have a Gates pulley 8MX-30S-12 that I've downloaded in .stp format from their site. I have 21 in my assembly, 18 components patterned and 3 individual. Lets say I want to change to an 8MX-28S-12 (that's 28 grooves vs 30 grooves) BUT when I "Replace..." i have to re-mate all the faces and edges.
Not the worst thing ever, but is there a way to streamline this process?
If you say sprockets - you've come to the right place
Go to 3D ContentCentral and download what you need from my library.
Each Sprocket file is per size #100, #80, #60, #50, #40, & #35 and what I did is split the parts per the shaft diameter, so yeah there are a few files, but they are manageable.
And..... Yes add them to your parts library, easy to change out if you need another size by using the replace component commands..
