Macro for variable dimension control
Question asked by Maris Balch on Oct 18, 2016
Latest reply on Oct 25, 2016 by Maris Balch
Hi all,
Not sure this is the right forum corner for the question.
I have an model that has set tolerances in each sketch. From my searching so far it doesn't appear that there is a way to easily see all these dims in a straightforward table with the aforementioned tolerances.
So I'm searching for a macro that can do what Autodesk Inventor does easily.
I wan't to get a similar table as above that can quickly switch between min/med/max tolerances and see the effects live? (i.e. have the model update as the tolerance is chosen).
I found an old macro (attached) written by Josh Brady here on the forums back in 2009, but am having issues with running it in SW2016 SP3. It complains that a 'method or data member is not found'. Can anyone help please? I'm completely new to macros.
Many Thanks,
Maris
