Driveworks is an excellent tool to create assemblies that change in dimensions (Width, length).
If I have a base model and from that model create 20 new sizes (driveworks will create the new parts for that 20 sizes), the parts are all identical the only thing that change is width\length. Now if I revise the base model (for example add a hole in one of the parts) there is any way to use driveworks to add that same hole in all the other 20 different sizes?
Otherwise I need to open part by part and add that hole in all the parts.
Many thanks
Unfortunately NO.
You can quickly make a library feature and place/add quickly in those files.
