Hi
(I'm not Anglish
I have difficulties since many times.I would like to create a texture as close as possible (or even identical
) than Lego Plastic, an ABS, with his own caracteristics (graphical
caracteristics, and not mechanical).
And then, have the most realistic render with all differents colors.
But I cannot, render is not good, pale, insipid yellow, ... with "half bright plastic".
Lights and scenes modifications change nothing. So, i search a better material, with best adjustement.
Initially, I took the "half bright plastic" without really worry about the quality of material for the rendering, it was not a problème, but now...
For information, all Lego colours are here: http://www.peeron.com/inv/colors and http://www.peeron.com/cgi-bin/invcgis/colorguide.cgi
i'm with SW2008, 2009 will come in next weeks.
If there AFL's, please, help :/
thx
PS: Its understandable?
(I'm not Anglish
thx
I'm learning PW, so I may be wrong, but I think you can actually edit many of the appearances colors to create those colors you want by entering the RGB values you have on that list in the appearances property manager. You can also choose "shiny" under color... I tried it with LEGO color 21 and it looks really similar. The shiny option looks better, regardless of if you use high-gloss or medium-gloss plastic.
Gabi
