Hi there, can anyone help me? I have an office layout that looks fine in preview mode but also renders out dark, I am using the same settings for render as well as preview and I have tried it with and without the "interior" option enabled. example renders to show what I mean:
Hi Stuart,
That's a good lookin' scene! Are you trying to do your final render in Fast or Accurate mode? Fast render mode is great for 90% or so of all Visualize projects, however fully enclosed interior spaces need Accurate mode to take advantage of those higher settings to bounce the light around the room.
Just an FYI - the hardest projects for any visualization software to render are enclosed spaces (rooms, cockpits, trains, etc) and jewelry.
Rest assured, it will render out realistically in Visualize, you just need to use Accurate mode and maybe crank up the brightness a little.
SW Visualize is a physically-based raytracing engine, which means what you see in the real world is what you will see in Visualize. If not enough light is bouncing into and throughout your enclosed interior space, then your scene will appear dark.
Doing one of these or all 3 in unison will give you the results you desire:
This next tip won't help make the scene brighter, but will help remove any noise in the final image. As a rule of thumb, most fully enclosed spaces need at least 2500 passes using Accurate mode in the final render. And depending on if those results still need more, then maybe 5000 passes will do the trick. Very rarely do you need to crank it up all the way to 10,000 passes.
Also, to check your pass count while you set up your project, look at the bottom middle of your screen in the Heads Up Display. Turn on Accurate mode first to see the realtime pass count.
Hope all this helps!
Brian
