So I have problems inserting datum features in my drawings.
When I start the feature, no mater what, the first datum is attached to the sheet where I click, not to what I click [-A-].
And I can't move it anywhere. It is just stuck and I have to delete it.
The following datums... data... The following datum symbols work as expected, clicking a line to select the datum object and clicking a second time to place the symbol where you want it. [-B-]
When I select a circular edge the datum symbol is okay [-C-], but when I select a dimension the datum symbol overlaps the dim [-D-].
When I try to extend the dimension line... weird things happen.
Either the datum symbol stays with the dim (not the line) [-E-] or it moves with the ext line by half [-F-].
So I can fudge placing datum symbols for the drawing if need be, but what is going on here?
Does anyone else see this behavior?
I had the same issues in SW15. I am currently on SW16 SP4.
