I'm working with 80/20, a material that's cut-to-length for building <stuff>. I could make a new part file for every length that I need, but I don't want to create a ton of parts.
I'd rather have on part for each profile (1010, 1020, etc.), then add a configuration for those each of those profiles for the particular length.
The problem I've got is that any time I edit the extrusion length for one configuration, it changes the length for all the other configurations. I tried making extrusions all at the same "tier" of configurations. When that didn't work, I deleted the base extrusion feature, keeping only the profile sketch, then added derived configurations. The derived configuration, I thought, would keep the sketch and allow me to create a unique extrude feature in each sub-configuration.
This is not the case. Instead, when I make an extrusion on one sub-configuration, it creates the extrusion in the parent (Default) configuration, which then gets suppressed. The other configuration then also shows the suppressed extrude feature.
What am I doing wrong?
Click on the feature in the tree (or double-click if you don't have Instant 3d turned on) to show the dimension in the graphics area.
Right-click on it and choose "Configure dimension" from the drop-down. That will open this simplified design table. Enter the desired value for each configuration in this column.
