Ben Heath
Normal Cut?
Discussion created by Ben Heath on Oct 8, 2008
Latest reply on Oct 8, 2008 by Kenneth Barrentine
I have run into issues with the Normal Cut feature in Sheet Metal parts. I found that when I can't make certain cuts with the normal cut feature checked, I can uncheck it and the cut seems to work just fine. However, when I export to .DXF for laser cutting, the part file gets cut out a bit different from my part file. Anyone else have this problem? Can someone explain the normal cut feature?
