FHFred Hoffmaster13/10/2016
Does anyone know if there is a way in SolidWorks to create a variable/multi-angle draft?
Basically, as shown in the attached file, I am looking to transition a draft around curves. One side may be 5 degrees and transition around the curve to 3 degrees and so on.
I used to work in Pro-E, and this was a fairly simple process. You would pick points where you wanted to specify draft angles and the program would automatically create the transition.
I'm sure I could do this in SolidWorks with a blend, or surfaces, but I was hoping for a simpler and quicker solution.
Thanks in advance!
