I am new to SolidWorks and I just started my first "real" project.
I have encountered a problem while trying to loft my Sketches.
For some reason it produces weird lines and it just doesnt look how I want it to
My idea was to loft the sketches in order to create a Jet-Fuselage.
Could someone please help me?
Thank you!
One of the tricks with lofting is each sketch should have the same number of vertex's
Sketch 3 there are 4 points and sketch 4 you have six, keep those numbers the same for a smooth transition
Sketch 3 add a very small horizontal line at the top point
and two additional points at the bottom
Using the Split Entities tool
In sketch 4 split the bottom line in equal spaces by adding a point in the center
You can also add Guide Curves to flow the outside
