Rebuild doesn't work properly with global variables
Question asked by Francesco Occhioni on Oct 12, 2016
Latest reply on Oct 13, 2016 by Christian Chu
Hi all!
I'm having some trouble using VBA API with SolidWorks 2015 Premium.
I have a Project and a VBA marco in which i want just to replace the value of the global variables and suddenly rebuild the project.
There are 2 global variable Diam=5 and Height=5 and i want to replace their value.
My Macro is this:
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Dim swEqnMgr As SldWorks.EquationMgr
     Dim longEquation    As Long
     Set Part = swApp.ActiveDoc
     Dim myModelView As Object
     Set swEqnMgr = Part.GetEquationMgr
     'Delete old variable and add a new one with the same name
     swEqnMgr.Delete 2
     swEqnMgr.Add2 2, ("""Diam"" = 10"), False
     swEqnMgr.Delete 3
     swEqnMgr.Add2 3, ("""Height"" = 15"), False
     'Evaluate all equations
     Dim ret As Integer
     ret = swEqnMgr.EvaluateAll()
     MsgBox "Diam value : " & swEqnMgr.Value(2), vbOKCancel
     MsgBox "Height value : " & swEqnMgr.Value(3), vbOKCancel
     'Rebuild
     boolstatus = Part.EditRebuild3()
     MsgBox "rebuild : " & boolstatus, vbOKCancel
The main problem is that the EditRebuild3 doesn't work properly and i don't know why.
Suddenly the macro run,  i go to "Manage equation" panel and see that the macro change correctly the value, and pressing the rebuild button seems do it work properly.
Would you please help me? (i have attached all you need to run the macro)
Thanks a lot.
Best Regards
