I want to change the Solidworks assembly documents into STP, IGS, STL, or PROE formate without transforming all the part documents one by one since it is a complicated assembly with almost one hundred parts. Does anyone have any ideas on this issue? I was trying on the "save as", "pack and go". Thank you so much!
Save as
save as type of file, select stp, igs, stl, parasolid
there are some options like save just exterior faces, all bodies etc
hope this helps
