So if anyone wants a challenge, here is the part for you to enjoy. I modeled it pretty close using just the basic commands.
for some reason, I can't attach the actual model, but here is a jpg.
Thanks. I'll zip the files.Kelvin Lamport wrote:
You have to compress (zip) SW part files to be able to upload them.
Just as SW can create parts which are impossible to create in the real world, parts that exist in the real world aren't necessarily create-able in SW.
If the real part involves actual plastic deformation (stretching and thinning of material) SW will not be able to reproduce it as a flatten-able sheet metal part.
What are you doing on here while you are on vacation? Put the computer down, and step away slowly.Anna Wood wrote:
I am actually on vacation this week.
Cheers,
Go relax and have some fun watching model airplanes.
You are awesome. I never thought of using a much smaller blank size. I think I can get it figured out now.Kenneth Barrentine wrote:
see attachment.
blank size was changed to a .04" cube so that no second operation was required (trimming blank).
one of the end faces where tube transitions to flanges set for removal.
did not have a "slit" and the "tube end" being removed.
hth
Everyone knows that the thickness of the sheet metal must be less than the minimum radius of curvature of the form tool. For some reason SW is getting confused about this.
The sheet metal thickness is .040
The minimum radius of curvature for the form tool is .050
I've tried adjusting both values a little more both ways to try and make it work.
