Some of our users like to use an asterisk in front of the part number they are searching for so they do not see other results that may contain the number within. When doing this it will not find the number in a multi-line field which we have for legacy 2D tab drawings.
Has anybody run into this or does anybody have any suggestions as to how we could get around this without having to write code?
Thanks Chris for the link, I will be putting this link in our Friday announcements but that is not the issue.
For a tabulated drawing you have multiple part numbers. For Example our part number field in our data card would look like this in our data card for a tabulated drawing.
1000001
1000002
1000003
"No spaces in between" Because this is one text variable it would be one string, something like 1000001 1000002 1000003
So an exact search will not work..
Because we have drawings that go back to 30 plus years ago and the multiple erp and numbering scheme's through out the years we have instances like"
part number = 60345 and another file with a part number = 10603450. If I search for 60345 I will get both files. If I search for *60345 it will only return the first one and that is how I would expect it to work.
The problem comes with the tabulated drawings that have multiple part numbers in the data card, if you use the asterisks it will not find any of the numbers in these cases. It makes sense since the multiple part numbers are all part of one string that it is searching.
We could write a search but I am trying to reduce the amount of customization that we already have.
At first I was thinking it was a bug with the asterisk search when multiple part numbers existed in a data card but after thinking it through I realize it is working properly.
If there was a data card filed that would act like an object array...
I appreciate everyone's efforts and conversations and sorry for the confusion.
