Hello
Does somebody know if there is a mean in Composer to export views (in a .smgView file or an other way) keeping the differents authors present in the view, to import the view in an other .smg file without create all these authors again ?
Thanks for your answers !
(sorry about my english I'am not a native speaker)
Hi
most of the authors are directly linked to geometry (Labels, callouts, cutting Planes, path, arrow etc)
If you want to use an .smgview file, you have to use the same geometric structure as well.
If you use another assembly, the infos within the smgview file dosnt fit and nothing will happen.
You can use the .smgView file, if the structure would be very similar and you can exchange the different actor-names in the XML-Files (smgView & smgXml).
For different assembly structures you have no possibility to transfer authors!
