I created a pattern of points from Reference Geometry using Evenly Distribute and selected a spline. Originally I used 12 points but not I need to change it to 10 evenly distributed. How is this done?
Seems like you cannot change this as the definition of points is changed to distance once the pattern is created. Could you please clarify how do you use those points? Is this for geometry creation? May be you can use curve driven pattern with 'Equal Spacing' option which can be modified:
