equation add2 false error?
Question asked by Yannick Proulx on Oct 4, 2016
Latest reply on Oct 5, 2016 by Amen Allah Jlili
Hi Guys,
I have a little problem with the equation manager Add2 function.
when I delete all the equation that have instr "TEST"  then try to re add thoses equations (exactly the same equation that was delete previously),I get an return value of -1 on the add2 function but the equation is still added.
I debug print 40 equation at the beginning, then after delete the TEST equation I debug.print 27 and after all TEST equation re added I debug print 40 ...But I get a -1 on all add2 function...
Why am I getting a false error? and How can I prevent it?
One again Thank you for your time and Knowledge
Yannick
Here is My code Snippet:
        'file is loaded silently
        Dim EquatMgr As SldWorks.EquationMgr = swModelDoc.GetEquationMgr
        Dim EquaCount As Integer = EquatMgr.GetCount
        Debug.Print("Equation Count before delete : " & EquaCount) '<--------------------------------Equation Count before delete : 40
        ''check if equation already exist and if yes delete it
        Dim RetVal As Integer = Nothing
        Dim sEquat(EquaCount - 1) As String
        'Keep internal equation ,delete TEST equation
        For I = 0 To EquaCount - 1
            If InStr(EquatMgr.Equation(I), "TEST") > 0 Then
                RetVal = EquatMgr.Delete(I)
                If RetVal = -1 Then
   msgBox("An error occured while suppressing equation : " & EquatMgr.Equation(I))
        Next
        EquaCount = EquatMgr.GetCount
        Debug.Print("Equation Count after delete TEST equation : " & EquaCount) '<--------------------------------Equation Count after delete TEST equation : 27
        Debug.Print("TEST Equation to be added : " & EquationDict.Count) '<--------------------------------TEST Equation to be added : 13
        For Each equation In EquationDict.Values
            RetVal = EquatMgr.Add2(-1, equation, False) '<--------------------------------HERE IS THE RetVal = -1 but the equation is still added
            If RetVal = -1 Then
                MsgBox("An error occured while addin equation : " & equation )
        Next
        Debug.Print("Equation Count after all equation added : " & EquatMgr.GetCount) '<--------------------------------Equation Count after all equation added : 40
