How do I sweep this surface profile while keeping the top of the radius parallel to the plane below? I've tried path alignment with direction vector but it still won't achieve what i'm after.
Not sure what you mean by "keeping the top of the radius parallel to the plane below"... But usually when I do a more complicated sweep or loft I use lots of guide curves. If you want your half circle shape to maintain a particular shape throughout the sweep then you should have 3 guide curves, one along each side of the half circle, and one along the bottom of the arc.
Can you upload your part ?
Did you try to add additional guide curves?
