ModifyDefinition not making changes
Question asked by Duncan M. on Sep 28, 2016
Latest reply on Sep 29, 2016 by Duncan M.
I am try to modify the thickness of a lofted bend.
For my example macro, I first select the lofted bend, and then run it.
I get the definition of the feature, change the thickness value, and then call ModifyDefinition.
Nothing changes in the part, and when I call getDefinition again I can see that nothing has changed in code either.
Option Explicit
Dim swModelDocExt As SldWorks.ModelDocExtension
Dim swFeat As SldWorks.Feature
Dim featName As String, featType As String
Set swModel = swApp.ActiveDoc
Set swModelDocExt = swModel.Extension
' Get the selected feature
Set swFeat = swSelMgr.GetSelectedObject6(1, -1)
Dim lbfd As SldWorks.LoftedBendsFeatureData
Set lbfd = swFeat.GetDefinition
Debug.Print "Thickness: " & lbfd.Thickness
lbfd.Thickness = 0.01
Dim bRet As Boolean
bRet = swFeat.ModifyDefinition(lbfd, swModel, Nothing): Debug.Assert bRet
' Debug messages follow:
' This is my changed thickness:
'  See what the feature sees as the thickness:
' It shows the original thickness therefore modifydefinition did not work.
