Rename current sheet to "DXF" and load DXF sheet format
Question asked by Garret Hansen on Sep 26, 2016
Latest reply on Sep 27, 2016 by Garret Hansen
Hello, I have a macro that quit working when I updated to SW 2016 SP4.  Some of my other very similar macros still work but this one does not.  This was a modification to one of Deepak Gupta's macros.
What it does is it renames the currently selected sheet to DXF, it then loads a custom DXF sheet format and also sets the scale to 1:1.
I can't figure out why it isn't working now that I have updated to SP4.  I get a Compile error: Object library feature not supported.
Start of Code **************
'DXF_Current_Sheet_Format.swp --------------------- 03/18/2015
'Modified version of ----------- Reload Drawing Sheet Format.swp ------------- 06/05/14
'Description: Macro to Set Drawing Sheet Format for current sheet to DXF.
'Pre-Condition: An active drawing document having any sheet format.
'Post-Condition: Macro will set the sheet format to DXF.
'Might delete everything contained within the old/exisitng format.
'Please back up your data before use and USE AT OWN RISK
' This macro is provided as is.  No claims, support, refund, safety net, or
' warranties are expressed or implied.  By using this macro and/or its code in
' any way whatsoever, the user and any entities which the user represents,
' agree to hold the authors free of any and all liability.  Free distribution
' and use of this code in other free works is welcome.  If any portion of
' this code is used in other works, credit to the authors must be placed in
' that work within a user viewable location (e.g., macro header).  All other
' forms of distribution (i.e., not free, fee for delivery, etc.) are prohibited
' without the expressed written consent by the authors.  Use at your own risk!
' Written by: Deepak Gupta (http://gupta9665.com/)
' Edited by Garret Hansen 03/18/2015
'Option Explicit
Dim swApp           As SldWorks.SldWorks
Dim swModel         As SldWorks.ModelDoc2
Dim swDraw          As SldWorks.DrawingDoc
Dim swSheet         As SldWorks.Sheet
Dim vSheetProps     As Variant
Dim vTemplateName   As Variant
Dim sName           As String
Dim nErrors         As Long
Dim nWarnings       As Long
' Change sheet format location here
Const sTemplatePath As String = "C:\RDIVault\ENGINEERING\SW TEMPLATES\"
Set swModel = swApp.ActiveDoc
' Check to see if a drawing is loaded.
If swModel Is Nothing Then
        MsgBox "There is no active drawing document"
        Exit Sub
If swModel.GetType <> swDocDRAWING Then
        MsgBox "Open a drawing first and then TRY again!"
        Exit Sub
Set swDraw = swModel
        Set swSheet = swDraw.GetCurrentSheet
        sName = "DXF"
        swSheet.SetName (sName)
        vTemplateName = "DXF-TBLK-in.slddrt"
        vSheetProps = swSheet.GetProperties
        vSheetProps(2) = 1
        vSheetProps(3) = 1
    'Set the sheet format from the speicifed location
    swModel.SetupSheet5 swSheet.GetName, swDwgPapersUserDefined, swDwgTemplateCustom, vSheetProps(2), vSheetProps(3), False, sTemplatePath & vTemplateName, vSheetProps(5), vSheetProps(6), "Default", True
    swDraw.ViewZoomtofit2
    swDraw.ForceRebuild3 False
    swDraw.Save3 1, nErrors, nWarnings
Set swDraw = Nothing
End of Code **************
