I'm a new user to CosmoWorks and FEA in general. I'm working
on a project that involves torsion in a hollow tube. I'm making
some general assumptions based off calculations for torsion in
tubes as outlined in "Mechanical Engineering Design" by Shigley and
Mischke. When I initially started the project, the calculations and
the FEA were off by a factor. So in order to enhance my
understanding of Cosmosworks, I picked two sample problems from the
book. They are of torsion in a round tube and a rectangular tube.
In the round tube problem, I took the properties for 1018 steel as
seen in the attached pic and assumed a 3000 lbf-in input about the
centerline axis. The book indicates that I should be getting 44,427
psi shear stress whereas Cosmos is showing 78,480 psi as seen in
the attached pictures. In the rectangular problem, I used the
material properties defined in the problem and used a 23,728 lbf-in
input, from the problem, with an axis generated from the center of
the rectangle. The book indicates that I should be getting 11,500
psi shear stress whereas Cosmos is showing 130,800 psi as seen in
the attached pictures. Both tubes are constrained by their bottom
face and have an applied torque about the top face. Is there
something I'm not addressing here?
EDIT: I finally managed to work that counterintuitive attachment java app. Here are the attachmets. The problems are in the 7th edition pages 144-145. Thanks for the input.
I do not see any pictures. There are many factors that could be influencing your results from how the study was set up to mesh size and everything in between. What edition of Shigley are you looking at? I have the 7th Ed; if you tell me what page the problem is I might be able to try and run it myself.
Steven
