Converted a step file to a part file, designed a fixture for the part, now when i delete the part to leave just the fixture, everything wants to delete.
Any insight? When i go to hide the part the fixture disappears. same for the suppress.
Thanks!
Thanks!
It seems like you have dependencies between the part and the fixture, like points in fixture sketches that snap to part edges. You can right click the fixture and select Parent/Child to see the dependencies.
There is an option to delete features without deleting the dependencies. It's in the window that you confirm the delete in.
I would rather not delete the original part, but when i try to hide or make it disappear, the fixture disappears with it.
As Deepak Gupta said, Delete the body. That will create a new feature at the bottom of the tree, so anything done earlier shouldn't be affected.
