Has anyone form SolidWorks (or anyone else) solved this yet???
The recommendation of my VAR was a total uninstall, clean registry and reinstall.
SAME problem only now I've lost 4 hours!
Muggs
Mark Biasotti wrote:
Muggs,
Since your install, have you tryed re-registering your SWPro license? To do this you go to control panel>Add or Remove Programs>SolidWorks 2009 SPO "change" and run thru the dialogs to "Modify" pick SW pro and then proceed to serial number and then let SW re-register.
Now try PhotoView. Same Problem? Yes
The next thing I would do is
- to remove "PhotoView 360" from your Add or Remove Programs
- remove the folder:C:\Program Files\SolidWorks Corp\PhotoView 360
- do a manual regedit for any occurances of "PhotoView"
- Reinstall using the separate download of PV from the manual install
- re-register SW like mentioned above
- Launch PV 360
Same Problem? Yes
Do you have a SW Office Professional license or an earily SW Office or separate PW license add-in?
SW Office
BTW, Help>Show Licenses shows - SolidWorks Office / Never
Hope this helps - I'll check back in later
mark
- Launch PV 360
Same Problem?
mark
