Well, it seems that several years later, this issue still bothers some folks (like me...) I found something that might help others. If the last item I copied into the clipboard (ctrl-c/x) is a file (like a sldprt or possibly even a jpg) then I would get the "OpenClipboard" error when inserting a component. When I copy plain text into the clipboard, the error would not show up.
Hopefully that helps and is an acceptable workaround.
I use Ditto as a clipboard manager and I find that a quick "launch Ditto hotkey and then Enter" will load my top sticky clip (which is plain text) into the clipboard and replace whatever was there.
-Nate
Make sure you've sufficient space on the hard drive. Also restart system and check again.
