Internal error: The Windows Installer for this product component did not run as expected: InstallExecute.
Contact Technical Support.
When contacting Technical Support about installation issues, you will need to provide the installation log files available in this directory. Use the button below to save your logs as a zip file for sending to your support representative.
I've tried to uninstall the 2015 version and I just cannot get 2016 to work...
different drives, anti-virus, permissions, delete registrations, turn off UAC... I've touched enough for that.
Can anyone give me a solution? Thank you !
[E 158 1 MSIInstaller.cpp(3246) 21:56:36] $S21:56:36 Error Status 158 0 "***END DUMP OF WINDOWS INSTALLER DATA***"
[E 0 1 MSIInstaller.cpp(3191) 21:56:36] ** Install FAILED with code 1603
[E 154 1 MSIInstaller.cpp(3192) 21:56:36] $S21:56:36 Error Step 154 0 "** Install FAILED with code 1603"
