John and others not using the mold tools.
I understand some aspects of NOT using the mold tools. Such as drafting filling the hole and extending out the shut off surfaces.
But, how do you avoid not using the parting line tool and the Tooling Split Tool.
The Shut-off Surfaces tool creates the cavity and core surfaces for you and the Tooling split tool creates the cavity and core body for you.
How do you do it without using these tools and is it really easier? I am not questioning how you do it or weather you are right or wrong. I just dont understand how to avoid it. Could you give a quick note on how to do it without the tools
Thank you for you help, and consideration.
Mike
Mike
If I was starting out in mold design and/or SW I would probably take the time to learn and use the tools, but as I said I have tried them in the past and I am far quicker at getting a layout done by chisseling away at a block with standard SW tools and surfacing tools. Whether or not you use Mold Tools I think may depend on the complexity of the part. I have designed intake manifold tools with many PL steps that were generated from complex non uniform surfaces and the amount of time it took to get the part split was painful (again my inexperiance). The companies I work and have worked for are always looking for fast layouts and no matter how many times they say"just a quick concept", I get in a design review and they want to see all the shutoffs, core pulls ect. In short I need to just get it done and I am faster going old school utiluizing anything new that comes in the latest release.
