7 Replies Latest reply on Sep 20, 2016 3:34 PM by Sanya Shmidt
    Restore SW settings via API
    Sanya Shmidt
      Hello Everyone!
      Is there a way to restore silently via API solidworks settings *.sldreg? We are experiencing anomaly on some computers at work. We tried different solutions (re-installing/restoring ) . Seems like it randomly happens. The command manager tabs disappear, task pane EPDM icon disappears. Just tired of this behavior.
      We also tried to completely remove registry and adjust SW from zero. It worked for a while and then stopped......
      Thank you,
      Alex.
        • Re: Restore SW settings via API
          Deepak Gupta
          Once you set up SOLIDWORKS as desired, then you can export the registry keys. And then can set up to run the registry file (bat file) via Windows API  on system start.
            Christian Chu
            I have my own settings via API, mostly from system options (files location, templates etc) - I'm not sure if you can restore things like tab missing via API ?
              Sanya Shmidt
              ok, after playing with the batch/reg files, I come up with the following script that basically runs the SW_DefaultRegistry.bat file which fires the registry file SW_DefaultRegistry.reg every time I run our configurator app.
              Solidworks *.sldreg files are same as *.reg file. you just need to rename extension.
              ' Restoring Registry every time app starts only for "SpecificMachine" machine
                         If (System.Environment.MachineName) = "SpecificMachine" Then
                             My.Computer.FileSystem.WriteAllBytes("C:\Users\Public\SW_DefaultRegistry.reg", My.Resources.SW_DefaultRegistryREG, False)
                             My.Computer.FileSystem.WriteAllBytes("C:\Users\Public\SW_DefaultRegistry.bat", My.Resources.SW_DefaultRegistryBAT, False)
                             Process.Start("C:\Users\Public\SW_DefaultRegistry.bat")
              SW_DefaultRegistry.bat file see below:
              echo off
              REM Registry restorer
              REGEDIT /S C:\Users\Public\SW_DefaultRegistry.reg
              I guess the bat file can be also added to AutoRun so it pushes the registry data when computer boots up.
