I was doing an investigation on a scenario in which you publish a 3D PDF but you forgot to include part weight as a custom property in your template.
Would it be possibile in Acrobat 3D to display part mass of your 3D PDF ?
I've found out that by activating "Show Physical properties you can find out part volume":
In that case if you know part density you can figure out, but what if you don't know part density ?
So my questions are:
- does part density get written in the 3D PDF file ?
- does part mass get written in the 3D PDF file ?
Alex
