Interesting. I've always used tab for that instead of the
"command option toggle".
One thing that can prevent changing sketching alignment in a 3DSketch is if the view is nearly perpendicular to the plane your trying to toggle to. At other times, it seems to refuse to change for no apparent reason after I've begun a line segment. Trying again usually gets it for me.
Regards,
Mike Radoiu
Thanks for the quick answer. When I switched to an isometric view the TAB key works.
