I am missing the default templates. There are simply no folder with that content to point to.
Can these be downloaded somwhere?
Regards Martin
Regards Martin
Check this post if that helps to understand/fix the location of the templates http://www.javelin-tech.com/blog/2015/08/solidworks-default-template-location/
You can also ask your VAR (company you bought SW from) to send you the templates OR someone here can upload also in case above doesn't help.
