In an assembly, mating a feature to a primary plane (a best practice), when selecting a face of a part, then I like to hover over the primary plane on the in-model-window tree that appears during mating such that the plane appears in orange highlight. On one machine I use, this happens as desired (see image below). I use 2 machines with SW2016, and each behave differently - on another machine, the planes do not appear while hovering. Does anyone know where this setting is?
Note that I prefer to keep the primary planes not visible in general, only want to see them at hover during mating. Thanks in advance for the help.
Hi Scott,
The option you are talking about is called Dynamic Highlight.
You can go to System Options>Feature Manager and make sure to check this option.
I hope this helps.
