If I open a new file is get a fatal error (see below)
When I try to access an existing file I get similar errors saying it can't acces temp files.
I tried reinstalling, I have no other processes running, I tried deleting everything in the temp folder but nothing works. At start of the application the temp files are made, eve before i want to open a document.
Error message:
An error has occurred. Please contact Bunkspeed for assistance.
Error occurred at 01:37:47 on Thursday, 15 September 2016. Build version is 2016.1.55.4166.
System.IO.IOException = "The process cannot access the file 'C:\Users\TVR\AppData\Local\Temp\SOLIDWORKS\SOLIDWORKS Visualize\a6fd2c67-3da9-46cb-a74a-b7f2092d1337\Project.xml' because it is being used by another process."
Stack Trace:
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize)
at System.IO.File.OpenFile(String path, FileAccess access, SafeFileHandle& handle)
at System.IO.File.SetLastWriteTimeUtc(String path, DateTime lastWriteTimeUtc)
at System.IO.Compression.ZipFileExtensions.ExtractToFile(ZipArchiveEntry source, String destinationFileName, Boolean overwrite)
at Bunkspeed.Common.DataModel.Manage.ProjectPackageLoadSave.ExtractAndInitializePackage(Stream packageStream, IProjectPackageDataStore projectDataStore)
at Bunkspeed.Common.DataModel.Manage.ProjectPackageLoadSave.Load(String packageFilePath, IProgressState progressState)
at Bunkspeed.Common.DataModel.Manage.ProjectDocument.NewProjectFromTemplate(String title, String templatePath)
at Bunkspeed.Common.DataModel.Manage.ProjectDocument.NewProjectFromTemplate(String title, Stream templateStream)
at Bunkspeed.Rendering.ApplicationLayer.Controllers.DocumentManager.NewProjectFromTemplateInternal()
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Threading.ThreadHelper.ThreadStart()
Hi Tom ,
I have not seen this particular issue before but it might help when reinstalling to do a registry clean of visualize as well, but that is really just a guess at this point.
maybe Bastian Krueckeberg or Brian Hillner can shed some light on this issue
