Every time I try to use the Midpoint Line function in SW2015 pro, SolidWorks crashes.
I never had this problem in earlier versions and my co-workers don't see the problem sing 2015 std. or pro.
I have tried it with SP1.1, SP4 and SP5 and still the same results.
Even when I start a new drawing, click on the sketch tab, select the line pull down and select Mid point line, select a plane, place my first point, drag out to space and then Click - I get the crash
Any ideas what could be causing this?
I don't often use the midpoint line but when I forget it will crash and select it I usually end up loosing a lot of work and have to start over.
It will do it in an existing part when I go to edit a sketch - even in a part created in an earlier version or on another system.
It's got to be a screwy setting I made but I can't figure out what.
I thought maybe something in a template I use but that wouldn't explain it happening when someone else made the part and I edit it.
These are my system options for sketch
Hi Rick:
Can you capture a crash incident using Rx and send it to your Value-added Reseller?
Alternately, you can try to start the SOLIDWORKS in ' Safe mode' and try again.
