7 Replies Latest reply on Sep 16, 2016 8:39 AM by Cuinn Herrick
    Macro: Is file from the Design Library?
    Cuinn Herrick
      Hi all, I am currently modifying Adam Hoffman's clean configuration macro so that it excludes cleaning design library items. Although I am currently having trouble nutting out the best way to assassin if parts and components come from the design library. Has anyone tried this before? So far I written 2 subs.
      Array of Design Library Addresses Macro:
      Sub DesignLibraryList()  'Get list of users Design Library's (Content Manager Folders)
          Set swModel = swApp.ActiveDoc
          Dim vsplit() As String
          Dim DL_REG_KEY As String
          vsplit = Split(swApp.RevisionNumber, ".") 'Get Solidworks Version Year
          DL_REG_KEY = "HKEY_CURRENT_USER\Software\Solidworks\Solidworks " & CStr(1992 + vsplit(0)) & "\ExtReferences\Content Manager Folders"
          'Debug.Print DL_REG_KEY
          On Error Resume Next
          Dim wsh As Object
          Set wsh = CreateObject("WScript.Shell") 'access Windows scripting
          RegKeyRead = wsh.RegRead(DL_REG_KEY) 'read key from registry
          vsplit() = Split(RegKeyRead, ";") 'Seperate strings
          For i = 0 To UBound(vsplit, 1)
          Debug.Print vsplit(i)
          Next i
      File Address Macro:
      Sub CurrentFileLocation()
          Dim swPart                      As SldWorks.PartDoc
          Dim swAssy                      As SldWorks.AssemblyDoc
          Dim bRet                        As Boolean
          Dim MyPath                      As String
          Dim MyFolder                    As String
          If swModel.GetType() = swDocumentTypes_e.swDocPART Then
              Set swPart = swModel
          Else
              Set swAssy = swModel
          MyFolder = CurDir$
          MyPath = Left(swModel.GetPathName, InStrRev(swModel.GetPathName, "\") - 1)
          Debug.Print "File = " & swModel.GetPathName
          Debug.Print "Folder = " & MyPath
      Any help would be appreciated.
        • Re: Macro: Is file from the Design Library?
          John Alexander
          Your first sub is querying a registry value of the current SolidWorks session for a semicolon delimited list of design library directories and then parsing it into an array of strings.
          Your second sub is getting a reference to the specific swPart or swAssy (which appears to be unnecessary) and then splitting the current model document's full path into a directory and filename.
          To check that the active document is a design library part, check if any of the design library directories stored in vsplit() are left-oriented sub-strings of the MyFolder value.
          I believe something like this would do the job:
          flag_found = false
          For each directory in vsplit()
               if InStr(1, MyFolder, directory, CompareMethod.text) = 1 then
                    flag_found = true
                    exit for
               end if
          next directory
          You can get rid of the portion of the second sub that checks the document type.
          1. If swModel.GetType() = swDocumentTypes_e.swDocPART Then
          2.         Set swPart = swModel
          3.     Else
          4.         Set swAssy = swModel
          5.     End If
            Cad Admin
            Are you referring to toolbox type components...
            If so use swToolBoxPartType_e to determine part file type.  Use that bases to add or exclude the part file...
            2016 SOLIDWORKS API Help - swToolBoxPartType_e Enumeration
              Scott Stuart
              That entire first sub is not necessary. Just add this line to the second sub:
              LibraryPaths = swApp.GetUserPreferenceStringValue(swFileLocationsDesignLibrary)
              It's not even necessary to split the paths into and array and loop through the array. All you need is something like this:
                   If instr(LibraryPaths, MyPath) Then DesignLibraryFile = True
                Keith Rice
                'Demonstrates how to determine if a component belongs to the Design Library.
                'Preconditions: Component is selected.
                'Results: See immediate window.
                'Written by Keith Rice
                'CADSharp LLC
                'www.cadsharp.com
                    Set swComp = swSelMgr.GetSelectedObjectsComponent3(1, -1)
                    Dim result As Boolean
                    If IsDesignLibraryComponent(swComp.GetModelDoc2, result) Then
                        If result Then
                            Debug.Print "Component belongs to Design Library."
                        Else
                            Debug.Print "Component does not belong to Design Library."
                    Else
                        Debug.Print "Failed to determine if component belongs to Design Library."
                Private Function IsDesignLibraryComponent(compModel As SldWorks.ModelDoc2, _
                    ByRef result As Boolean) As Boolean
                    If compModel Is Nothing Then
                        IsDesignLibraryComponent = False
                        Exit Function
                    Else
                        IsDesignLibraryComponent = True
                    Dim strDesignLibraryFolderList As String
                    Dim vSplit As Variant
                    Dim strModelFolder As String
                    Dim i As Integer
                    strDesignLibraryFolderList = _
                    If compModel.GetPathName = Empty Then
                        result = False
                        Exit Function
                    strModelFolder = Left(compModel.GetPathName, InStrRev(compModel.GetPathName, "\"))
                    vSplit = Split(strDesignLibraryFolderList, ";")
                    For i = 0 To UBound(vSplit)
                        If InStr(1, strModelFolder, vSplit(i), vbTextCompare) = 1 Then
                            result = True
                            Exit Function
                    Next i
                    result = False
                End Function
                Keith
                SolidWorks API Training and Services
