After using "Knit surface" to combine faces, there are still
lines between faces
Is there a way to delete these lines?
Thx, Chris
Thx, Chris
i was just having this problem. Resolved by following Wingman182's comment on this reddit post:
https://www.reddit.com/r/SolidWorks/comments/599rte/how_to_remove_lines_from_merged_surfaces/
To summarise, do system options, display/selection, and change 'tangent edge display' to either phantom or removed.
Worked for me. It even contained the setting to the one part i wanted to change, and left the rest of the assembly alone. You might have to set it in the part design window (ie no assembly window) for this though.
Cheers
If you are taking the part into a drawing, and you want the edges to be hidden, you can either:
recreate the transition between the two surfaces to make it perfectly tangent (good luck!)
or more realistically, you can just use the tool in the Line Format toolbar called "hide edge". You will have to do this by hand for every edge in every drawing view.
