Hello everyone!
I have a problem want to request your help.
- I choose to show the texture, but I can not change the length of the red. I want to animation the red line movie the full length of the pipe sections. (Texture.smg)
I do not do the same as in the tutorial in video (3DVIA Composer fluid animation - YouTube.mkv)
- why while I import a assembly from solidworks into solidworks composer. when I rotation or zoom objects in solidworks composer, it always shows a frame containing it. In many other subjects can not (help.smg).
- Error view and rotation, Feels a bit jerky picture in solidworks composer 2016 (error view and rotation.jpg and help.smg)
Good luck!
Best regards,
Attach...
1. attached you find an idea to use texture.
i used a splitted texure half red half white to create the animation
Is this your idea?
The other possibility is to use geometry. to decide, what is better, depends on the situation. In this case you has to copy the original geometry, exlode it and use the inner frames (delete the outer). use the property "scale" and Change the scale from 0.01 to 1 for each Frame in the animation. one after the other.
2. your question to Rotation? There is not rotation.jpg in the file. i dont understand your objective. PLease give me more Infos.
