I am trying to model a part for Die Casting. A fillet on a inside corner is not ending at the appropriate parting line. Is there any way to end the fillet at the parting line ?
This is before the fillet.
This is after.
One other problem I have is that a 3d sketch converted from a edge shows some deviation from the edge itself. If anyone has any suggestions about how to model this part in a better way please feel free to suggest. I am attaching the part too just in case.
I found the same question asked by someone before but none of the methods mentioned in the post works for me.
Sourabh
If you can, first create a parting surface and the split the part in half. After you put in fillets, combine the two back together.
If the parting surface is too complex, see this thread: Ending fillets at the parting line
Dwight
