Gary Garrison
Render room
Discussion created by Gary Garrison on Sep 26, 2008
I have been setting a up a "render room" for our models. The plan is to be able to change out the wire decks as I need them and say GO. The renders then would be consistent and reproducible. The problem I am running into is that to get a decent render in PW , my SW lighting is way to bright.
Also I have apprently added all the spot lights I am allowed. The shelf beam is actually supposed to be blue like in the SW portion, but it renders white with the spraypaint texture. The wire deck is a patterned from a scan I made of our typical powdercoating.
I am attaching a picture of a what I see with right side of the screen rendered, and the rest as it appears in SW.
I could really use some help here, because I the renderings used to be so easy. They were only the decking assembly with a shelf beam added. I had to build them every time for each project. I was hoping this would help me out.
Any ideas anyone?
