The add-in says its loaded, but cannot find it anywhere to merge files into Esprit easier.
It is usually in the tools menu on the drop down, and in the bottom of that.
But its no where to be found.
I'm using Solidworks 2016 SP 3.0 with Windows 10.
If the add-in shows it should be loaded but you still cannot see it, you could try under the help pull-down and make sure there isn't a tab for it there as well. There may be a license manager that needs to be turned on.
We don't run Esprit but had a similar issue with CAM Works ever since we changed over to the network/floating license.
I don't have a lot of ideas left ...
You could try and see if there is a toolbar that could be turned on, or you can right click on the command manager and turn on the toggle for them there. At a minimum I would hope it should show up in "SOLIDWORKS Add-Ins" if nowhere else.
If none of this works I'd hit up your VAR and let them have a go.
After working with the Esprit guys, they came up with a macro to run in Solidworks that did this. And it worked.
And also found out they actually removed this feature from the add-in a few versions back due to the inconsistencies in performance across different Solidworks versions.
