Hi All,
2016 SP3. I have an assembly drawing that I placed an overall dimension on. The design changed and now the dimension is dangling, it cannot be reattached or deleted. When I select the 12.18 dimension to reattach or delete I get a cannot delete dangling dimension message.
I have not seen this situation in a long time. If you can undo the changes you made, you will be able to delete the dimension. You also may be able to hide the dimension. Unless you have done a lot with the drawing, I would recommend deleting the view and starting over.
