I have this Panel which I think isn't made well.
All the profiles you see are sheet metal. I have to do a configuration of it. How can I connect all the parts toghether that when I modify the overall Lenght, Height and maybe Width all the distances and the components inside to be automaticaly updated.
I have to mention that the model is highly parametrised and all the mates are made between planes and axes, and for a modification I have to spend a half of hour.
The exterior profiles, those which compose the frame are a single part with multiple configurations, and the interior profiles are one part with multiple configuration.
I tried with an ecuation but that changes all my configuration and I don't want that.
Will I have to have a single assembly without configuration formed by parts with one configuration connected through ecuations or I can have Assembly with multiple configuration formed from Partswith multiple configuration and all the dimesions to be connected throught ecuations between dimensions from parts and assembly?
I made the parts sheet metal because I cut them in laser.
If you dind't understand please tell me! Thank you!
A complicated pc a simple pc, I start "All" my projects that way, it was just quicker for me to show a simple assembly. It definitely takes more thought in laying it out, but the end result is pretty awesome when you have to make changes or delete any item in the feature tree, suppose you change your design mid stream, there will be some components that are ok, but if you're not careful in your design intent, your entire assembly can blow up by deleting one simple part or changing it from rectangle to round etc..
You can simply do what you want, I just know what works consistently for me...
Save a copy of the simple assembly in a different directory, then go and delete any item, change the sizes, check for interference's, delete the main assembly and start a new assembly and insert 9001 9002 9003 assemblies and see what happens, no mates to clog up the top assembly and you can work in zones, no need to work in the top assembly anytime.
Just my penny thoughts.....
